I need to use a fill feature on a CAD circle
Edit it to make it a Linestring then go to it's Properties and change the properties to Show Filled and pick a color - or use Hatch Pattern and fill it with a Solid or Hatch Fill - either way should work
Thanks Alan. Sorry for the stupid question. I was not thinking clearly.
No problem - no such thing as a stupid question either ....
On Thu, May 16, 2019 at 8:30 AM bflora@florasurvey.com <trimble@jiveon.com>
Alan,
I found my issue. When I convert the circle to a linestring via “convert to Linestring” in the macros: the fill option does not come on. If I convert the circle to a linestring via the ”EDIT” in the right click context menu
