Takeoff-Backfill quantities
  • 1.  Takeoff-Backfill quantities
    Posted 08-22-2018 07:15
    We have initial takeoff with temporary storm basins in the original takeoff (OG/with subgrades adjusted compared to FD/with subgrades adjusted).  I would like a workflow to re-compute the data in the same file to generate a takeoff report for backfill (FD/s with subgrades adjusted------ at temp storm grades compared to FD/with subgrades adjusted-----at finished grades).
  • 2.  Re: Takeoff-Backfill quantities
    Posted 08-28-2018 05:42
    As a work around, you can export your temporary basin surface as a DXF.  Then re-import the DXF back into Business Center.  You'l  have triangles from the surface on a layer.  Use this layer under 'original' ground when you categorize layers as your 'new' original ground.  This will give you a comparison from temporary basins surface to your finished grade surface when you run a Takeoff Report.
  • 3.  Re: Takeoff-Backfill quantities
    Posted 08-28-2018 09:23
    Bruce,
    Brian is correct on needing to export the surface as a DXF and re-import in. I usually do a (SAVE AS) and give the job the name of what I am comparing, then re-import the DXF in. This way I still have the original file.
    Mike
  • 4.  Re: Takeoff-Backfill quantities
    Posted 08-30-2018 13:17
    Bruce - does this answer your question - if not we need to do a 1:1 to look at your issue
  • 5.  Re: Takeoff-Backfill quantities
    Posted 08-30-2018 13:50
    Alan,
    This is not what the customer wants but I think it is the only way it can be done in TBC.  If he is still not happy I guess I tell him to keep using his Agtec.
    Bruce
  • 6.  Re: Takeoff-Backfill quantities
    Posted 09-06-2018 13:58
    What if you had takeoff/surface groups? You can then run your takeoff report based off a group of surfaces. Your default would look like (the traditional setup):
    Takeoff:
    • Finished Design
    • FD with subgrades absent
    • FD with Topsoil absent
    • OG with subgrades demolished
    • OG with topsoil absent
    • Original Ground
    • Strata: Ledge
    • Strata: Clay
    But then you could mix and match:
    Takeoff and Measured Strata:
    • Finished Design
    • FD with subgrades adjusted
    • FD with Topsoil absent ( subgrades adjusted)
    • Original Ground Field Verified
    • Strata: Ledge Field Verified
    • Strata: Clay Field Verified
    • Strata: Unsuitables
    Takeoff and Custom Subgrade:
    • Finished Design
    • Custom subgrade
    • Original Ground
    This would allow you to keep your original takeoff surfaces and setups with the BC file but also run calcs on different scenarios both purposed and real life.=. This would also be useful for VE situations.
    This is something I have struggled with myself on several occasions.
