I'm have used several RTN networks and have just discovered the following. My RTN vectors define the base station (network CORS) Antenna Information as Antenna Phase Center with an AdV Null Antenna. Do I need to change this info to the proper antenna? If so, does the Method change to Bottom of antenna mount or stay as Antenna Phase Center?
If the base station coordinates are defined at the Bottom of antenna mount (ARP), I would think the antenna would have to be defined.
