Transforming to local site
  • 1.  Transforming to local site
    Posted 06-24-2020 07:30
    I am getting this error when I try to convert my SX10 data from UTM10 to a local site:
    "Some points could not be computed due to transformation errors. Check your actual coordinate system settings."
    The shift works fine for RTK derrived points but my scan data and totalstations shots don't move to the local site.  I am using the same geiod and I have converted all the as-staked points but the problem persists.  Any suggestions for things to look at?
    Thanks,
    Tyler
    #sx10dataintbc #localsite
  • 2.  Re: Transforming to local site
    Posted 06-24-2020 15:46
    Hi Tyler,
    Which tool did you use, Site Calibration or Transform Survey Points?
