Drag & Drop to Import Files in TBC v5
  • 1.  Drag & Drop to Import Files in TBC v5
    Posted 01-22-2019 08:25
    Cannot drag & drop to import file into TBC v5.  I can drag a file to the TBC icon and import/open it if TBC is not running; but if there is already a project open I'm unable to drag & drop to import. ???
  • 2.  Re: Drag & Drop to Import Files in TBC v5
    Posted 01-22-2019 09:37
    Steven: I tested and got the same result. If you close the "Start" page then drag 'n drop works. Or, if you start a new default project you can drag and drop and it will open. I think closing the start page is quicker.
    Marshall
  • 3.  Re: Drag & Drop to Import Files in TBC v5
    Posted 01-22-2019 14:08
    If you have an open project in TBC v5 and you have the Plan View Open, are you saying that you cannot drag and drop a file into the Plan View Window?
    If there is no project open then you cannot import a file.
    Agreed that you cannot drag and drop a file to the start page and have it import - I don't think that is new or a "product issue" is it?
    If you are dragging and dropping a VCE File then the same applies - drag into an open project plan view and it will open OK. You can also drag and drop over the Start Page Tab or Plan View Tab (top of the Graphics area) and the VCE file will import.
    Let me know what I am missing here
  • 4.  Re: Drag & Drop to Import Files in TBC v5
    Posted 01-22-2019 14:22
    That is correct; If I have a plan view window open I am unable to drag and drop into plan view window.  Gives me the circle with line through it.  BUT without even having TBC open, I can drop a file on the TBC icon on the desktop and it will open in a plan view.
    <http://www.ryancentral.com/>
    Steven R. Vorpahl
    Field Engineer
    Mid-Atlantic Operations
    steve.vorpahl@ryancentral.com<mailto:steve.vorpahl@ryancentral.com>
    301.219.9855
    Ryan Incorporated Central
    16611 Hunter's Green Parkway
    Hagerstown, MD 21740
    <https://facebook.com/https:/www.facebook.com/RyanIncorporatedCentral/>
    <https://linkedin.com/https:/www.linkedin.com/in/steven-vorpahl-8934504/>
    www.ryancentral.com<http://www.ryancentral.com>
    This message contains confidential information and is intended only for the intended recipients. If you are not an intended recipient you should not disseminate, distribute or copy this e-mail. Please notify us immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. Therefore we do not accept liability for any errors or omissions in the contents of this message, which arise as a result of e-mail transmission. If verification is required please request a hard-copy version.
  • 5.  Re: Drag & Drop to Import Files in TBC v5
    Posted 01-22-2019 16:31
    Can you make sure that the Plan View WIndow is Open and is the focus
    Window. Also need to check the File type - if all else is correct the File
    may be seen as invalid for some reason - but if it is happening for all
    files there is something else going on as I dont see that in v5 or v5.01
    On Tue, Jan 22, 2019 at 2:22 PM steve.vorpahl@ryancentral.com <
  • 6.  Re: Drag & Drop to Import Files in TBC v5
    Posted 01-23-2019 10:05
    Are you running TBC as Administer? Windows does not allow drag-drop operations in this case.
  • 7.  Re: Drag & Drop to Import Files in TBC v5
    Posted 01-24-2019 12:03
    Thanks Gary.  That's what was causing the issue.
