GNSS SESSION EDITING
  • 1.  GNSS SESSION EDITING
    Posted 03-02-2017 17:40
    Greetings! Is it possible to change the date  & time in the GNSS Session editor?
  • 2.  Re: GNSS SESSION EDITING
    Posted 03-05-2017 20:11
    Hey Jason,
    You can use the session editor to remove noise sections of the baseline data by applying time edits, but you cannot change the actual date and time of the session.  This is considered part of the raw data.  Is there a reason for trying to adjust the date and time of the session?
    Cheers,
    Riley Smith
  • 3.  Re: GNSS SESSION EDITING
    Posted 03-10-2017 10:16
    Hi Jason:
    If you are trying to modify date and time of your raw GNSS data, perhaps a different approach is to create a Rinex file of your data.  You can then use a text editor such as Notepad or Wordpad to open and modify the Rinex "O" file.  Once modified, the Rinex file can be re-imported to TBC.  Although this can be time consuming (you will need to identify the required information in both the header and content  of the O file, then edit things epoch-by-epoch), it is certainly do-able.
    Regards,
    Greg Hazelquist
