Menu popping up after drag
  • 1.  Menu popping up after drag
    Posted 05-23-2020 06:33
     When I right click and drag the window the menu pops up as if I had right clicked without dragging.
    This has been happening for a while in other versions also. I have just gotten used to it and hit esc or click in the properties window to make it go away. It is annoying. I don't know how to make a screen video of it.
  • 2.  Re: Menu popping up after drag
    Posted 05-24-2020 11:51
    You mean when panning?
    What menu comes up - the snap modes menu if you have a command open and a swappable field selected or the context menu eg breakine etc if you have a line selected or the last used commands if you have nothing selected
    This sounds like it is a mouse issue ie you may have your mouse configured so that it clashes in some way or you have a fault on your mouse or your click speed is off
    You can pan also by clicking the wheel of your mouse
    I have not noticed this at all personally - has anyone else seen this?
    I will try this deliberately to see what happens also
  • 3.  Re: Menu popping up after drag
    Posted 05-25-2020 06:03
    It was the mouse it self. I changed the mouse and it works fine now. I thought it did it on my desktop also but it seems to be fine also. It was the mouse on my laptop. Thank you Alan for pointing me in the right direction. Since the mouse worked fine everywhere else I would not have thought of it.
  • 4.  Re: Menu popping up after drag
    Posted 05-25-2020 06:25
    I had the same issue in a different program the other day - different issue
    but same kind of thing - changed the mouse and it worked fine afterwards
    On Mon, May 25, 2020 at 7:03 AM tom@tomdewexcavating.com <trimble@jiveon.com>
