Run TML Status and then select the Voice Command TML and update it, also update Menu Manager and TML Status if you have not done that in the last week. Close TBC, Restart TBC and the problem should be addressed.
You probably should update all of your TML Macros at the same time as we did a major update over the July 4 weekend that gives you a new layout, new icons and many of the TMLs were updated.
If that fails please call me and we can do a go to meeting to fix you up. (+1 720 323 0481)
