3D rotate tool - does it exist?
TBC could have a 3D rotate tool like all 3D CAD packages. But I have not found it. Entities drawn on a vertical cutting plane cannot be output as a flat 2D CAD file because they remain vertical and there is no way to flip them to horizontal, within TBC. Interestingly, I can use the "mirror" command to flip it 180 degrees in 3D about any line, but can't 3D rotate by a known angle e.g. 90 degrees around a line?
The Transform by points command seems to be the likely candidate but any rotation is just done perpendicular to plan view (in horizontal plane) only.
It's pretty basic functionality so I feel like I must have missed something.
There don't seem to be any posts on here about it either!
Thanks in advance
