To IGNAS,
Thanks for the reply
To calculate the 3D surface area in TBC I have tried the Surface Information report which shows Total Surface Area.
But the problem is the surface created in TBC is not to the shape of the Point Cloud it have some Gaps in the Surface and shows the 3D surface area much higher than the Surface area calculated in Civil 3D software
(TBC Surface image attached)
cid:image009.jpg@01D43158.B5513C30
cid:image010.jpg@01D43158.B5513C30
Please find the Below google link of TBC Surface , Civil 3D DWG file and Reports TBC & Civil 3D
https://drive.google.com/file/d/12LU4jRKzhR2hxsby_V68-M4DlNY-1ea4/view?usp=sharing
please provide solution at the earliest
Thanks and Regards,
S.Srinivasa Rao
Technical Support Engineer
Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: cid:image001.png@01CCEBDD.B6D872C0
P.O.Box 38017
Dubai
United Arab Emirates
Tel: +971 (4) 339 2217
Fax: +971 (4) 339 2218
Mob: +971 55 899 3134
Website: <http://www.gtech-bmg.com/> www.gtech-bmg.com
Trimble SX10
