Hi Jason,
Great question! Oswaldo's answer will work if the points you want to create are at the same elevation as your starting point. The following workflow will work well if the point is to have an interpolated elevation and the offset distance is horizontal.
Short version:
Create Linestring between the two points. (direction matters)
On the Edit ribbon, use the break line command.
Create a point at End of line. (In Create Point drop-down)
Detailed version:
I have two points seperated by 141m horizontal, 10m vertical.
First is to Create Linestring between the two points, starting from the point you want to set the offset distance.
I have drawn the line from point 1 to 2. After opening the Create Linestring command, you can press "Enter" to skip the first menu, and go directly to selecting the start and end points of your line. After clicking the two points, pressing "Esc" twice will exit the command.
Next, go to Edit > Lines > Break
Select the line (if it's not already), and enter the distance along the line you would like to create the new point. (This is why the direction the line was created matters) I would like my new point to be 50m from the start point.
Hit Break or press "Enter" on the keyboard.
Next, CAD > Points > Create Point (select the drop down) > End
Select the end of the broken line, and click Add or press "Enter". A point will be created here.
If the linestrings are not desired, they can be deleted.
I hope this answers your question, if not let me know!
Thanks,
Matt
