Using The Cleanup Tool
  • 1.  Using The Cleanup Tool
    Posted 12-11-2018 15:40
    Alan very recently published a blog post about de-installing v5 and running the Cleanup tool if one was having problems. I am having problems and would like to try this. That said, I have v4.12 still installed because it still works for some of the issues I have had. The questions I have, does running the Cleanup tool damage or cause issues with v4.12? Is the tool self explanatory? I don't believe I've actually seen a set of instructions for the tool.
  • 2.  Re: Using The Cleanup Tool
    Posted 12-12-2018 08:21
    I am waiting for a colleague to get into the office this am before answering this question. I will get the difinitive answer for you before responding - Hope that is OK
  • 3.  Re: Using The Cleanup Tool
    Posted 12-12-2018 11:16
    Removing TBC should not remove HCE when run under the Advanced tab. If you run the Cleaner from the Quick tab, everything gets removed including HCE.
    I would also make sure that you back up all your Option Settings, Custom Templates, Custom Drafting Templates etc. prior to running this utility to Clean Up your Computer.
