I am trying to offset a toe of slope line to a certain elevation at top of berm in a fill situation. I feel like there is a way to do it but I am not finding the right command or workflow.
In my situation i have a top of berm elevation and a staked silt fence line at toe of slope. This is a field fit due to a creek avoidance on two sides of the location. I received points from the field where toe of slope needs to be and so I created a line there at planned toe of slope and I need to fill up to the berm elevation at a 2:1. It is a very irregular shaped location and toe of slope is a varying elevation all around the pad so i can't just offset to an elevation.
I tried create surface tie but I can't get it to tie up in a fill. I have tried to use my toe of slope line as a boundary and create a planer surface at a constant elevation at top of berm height to tie but I am not getting the results needed. I have my honor sign of tie turned to yes.
I hope I explained this well enough for someone to help.
Thanks
Dane
