Dane
Can you share a Project where you have that set up and I can take a look at what you have done and make suggestions here - You should do the following
1) Have a Plan Set
2) Create a Sheet Set for your Title Sheet
3) Add a Custom Sheet for your Title Sheet
4) Lay out your Title Sheet. If your main Title Box etc is at the Plan Set Level it will ripple down the Sheet Set and the Sheet that you create. You can lay out what you need on your Custom Sheet and it will then Print.
What I see sometimes is that People Create a Sheet Set and lay out the Title Sheet on that level and forget to create a Sheet to put it on. You can only print Sheets not Sheet Sets or Plan Sets.
If this answers the question let me know, if not send me a file (alan.sharp@rockpilesolutions.com) and I can take a look at it for you.
