Traverse Adjustment
  • 1.  Traverse Adjustment
    Posted 05-01-2017 11:35
    How do I get my traverse to close in on itself?  I have a traverse that was ran from 2 - 20 - 21 - 22 - 23 - 1, and then on 1 closed in on 2.  However when i go to adjust traverse, it will not close back into 1.
    In the preview results I get "Traverse configuration error
    The end station position and end foresight point are unknown."
  • 2.  Re: Traverse Adjustment
    Posted 05-05-2017 15:33
    Hey Dustin,
    This is a difficult problem to diagnose without seeing the data.  Can you send me the TBC project and I will take a look?  Also, there is a tutorial on using total station available that may give you some important information in the meantime...see below.
    Cheers,
    Riley
  • 3.  Re: Traverse Adjustment
    Posted 05-26-2019 02:07
    Hi Riley,
    I have performed a traverse and I am getting the same results as Dustin in the previous when trying to adjust it in TBC. Can you tell me what the outcome for this was and if the solution was straight forward.
    Thanks
    Carl
