Hi Tom
TBC v4.10
Feature Definiation Manager v9.0
Thank you for that, that is good info to know for when I get to the point where I am writing out to a GDB. My issue occurs when I am in TBC and have imported survey data and then load the fxl file for the purpose of processing feature codes. When I select the fxl file, that is when I get the "invalid file" warning. The edits that I have done to the fxl file include:
editing the "Code" to match the code within the TSC3 data collector
Changed some element colors for the "Feature layer"
varify that the named feature matches the GDB
I am using data from a .csv file that was exported from a TSC3. Within the .csv, I have edited the feature code to match the "Code" that I have created within the fxl file, and matched all of the attribute names to match the fxl as well. Within the fxl file, there are more attributes that came from the GDB than what was collected in the field survey.
The feature "name" and the "Feature layer" are what came from the GDB using the "Get GIS Schema".
I can open and edit and save the fxl file using "Feature Definition Manager".
