Corridor Surface Template Instruction
  • 1.  Corridor Surface Template Instruction
    Posted 08-21-2018 09:52
    Alignment geometry derived from as built conditions in some areas aren't correct to say.  This will happen often within a clients design that causes a bad rendering of the corridor.  The only way to work through this is to break up the alignment.  Each time you break out the alignment.  The process of reporting and drafting work flow can grow to a large rate.  is there any way to reduce this.
