Hey Saif,
Are you using a feature code library to collect the data (FXL file) ? If this is the case, you can import the FXL file into the TBC project and use the "Process Feature Codes" command to automatically generate lines.
If you are not using a feature code library, you can use the "Connect Points" command with the "Advanced Select" command to automatically create a line between the points.
There is a great tutorial on setting up feature code libraries for automatic CAD generation and view filter managers here:
Cheers,
Riley
