Merge two TBC files with DiNi data
  • 1.  Merge two TBC files with DiNi data
    Posted 07-26-2017 00:24
    I have two TBC files with DiNi level data each having several runs and independently adjusted. Common points are differing by about 46mm. I now want to merge the two files with Fixed Point heights from both files to get single adjusted point list. Is it possible.
    The two files are attached herewith.
    Thanks.
    Attachment(s)
  • 2.  Re: Merge two TBC files with DiNi data
    Posted 12-13-2017 14:19
    I've used TextPad to manipulate the raw files before to combine a number of individual Dini files into 1 file that contains all the runs and then import the new file into a new project.
