Flagged Objects on imported surface
  • 1.  Flagged Objects on imported surface
    Posted 07-10-2017 04:46
    When I import a LandXML file, I often get these flagged objects. Is there some way I can resolve this, globally?
    Thanks.
  • 2.  Re: Flagged Objects on imported surface
    Posted 07-10-2017 10:00
    Hey Saif,
    The flags in your example seem to be caused by your the 'Breakline Approximation Parameters'. You can increase the tolerances under Project Settings -> Computations -> Surfaces as shown:
    You can also turn off the visible flags in your plan view in the 'View Vilter Manager'
    Currently there is no way to turn off/ignore flags, let me know if that helps, thanks.
  • 3.  Re: Flagged Objects on imported surface
    Posted 07-11-2017 21:49
    Thanks.
    This was useful.
    On Mon, Jul 10, 2017 at 9:00 PM, adam_tigeris@trimble.com <
