How to create a Vertical Design Alignment
  • 1.  How to create a Vertical Design Alignment
    Posted 09-13-2017 00:54
    I have attached types of files.
    I have a Horizontal Alignment defined in TBC. I need to add the vertical definition to that HAL.
    How do I go about.
    In Terramodel I was using a TML : "Alignimp". It would import all data with Vertical Curves complete in one click. Do we have similar facility in TBC?
    Attachment(s)
    zip
    CL Profile 94-96K.csv.zip   724 B 1 version
    zip
    Faya-Qua Profile 3.pro.zip   16 KB 1 version
    zip
    CL Profile.txt.zip   98 KB 1 version
  • 2.  Re: How to create a Vertical Design Alignment
    Posted 09-24-2017 08:28
    Hello Saif,
    The vertical component of an alignment is tied to the horizontal alignment.  As such, you can create multiple vertical alignments per horizontal alignments.
    Once the horizontal alignment is created, right-click on it in Plan View or in Project Explorer, and select Edit.  A tabular-based edit window launches, one of the tabs is Vertical.  Click on the Vertical tab and click the Create Vertical Alignment button on the right.
    The vertical alignment editing menu launches where you can input the geometry.
    Hope this helps!
  • 3.  Re: How to create a Vertical Design Alignment
    Posted 09-24-2017 20:41
    Thanks for the response, a bit delayed though.
    This expects me to type in each and every element. I would rather be happy
    to import a CAD. Terramodel or CSV file. That would be more efficient and
    also more accurate especially when you are trying to create a TBC Corridor
    with information (Design) from external sources.
    Hope there is such a solution. If yes, please let me know.
    Thanks and Regards.
    On Sun, Sep 24, 2017 at 7:28 PM, joseph_blecha@trimble.com <
  • 4.  Re: How to create a Vertical Design Alignment
    Posted 10-16-2018 20:58
    This post remains not finally answered. Could you please revert.
    Thanks.
  • 5.  Re: How to create a Vertical Design Alignment
    Posted 10-22-2018 07:55
    I think Mike might have answered here:
    Station-Elevation import as VAL
    This will do most of what you are trying to do. There is some discussion on alignimp for TBC. Hopefully it will be soon..
  • 6.  Re: How to create a Vertical Design Alignment
    Posted 10-22-2018 21:20
    Thanks.
    This is for me a half way solution. I think I have to wait for the alignimp
    for TBC.
    Thanks again for sharing this info.
    On Mon, Oct 22, 2018 at 6:56 PM shea.huckaby@sitech-tejas.com <
