Select with wild card (*) in Feature code
  • 1.  Select with wild card (*) in Feature code
    Posted 08-01-2018 23:54
    If I have several points with feature codes, say AV01, AV02, AV03, AV10....How can I select all points with Feature code beginning with AV, like AV??, AV* etc. Also the possibility for *AV* etc.
  • 2.  Re: Select with wild card (*) in Feature code
    Posted 08-07-2018 11:48
    Hi Saif,
    To select points by part of a feature code in TBC, go to the Data ribbon, and select Advanced Select
    Use the options as shown below:
    That is:
    = Equals regular expression
    This value:
    ^AV
    The ^ before AV selects all feature codes starting with AV, such as AV1, AV2, AV3, AV end, AV start etc.
    Entering "AV" into the This value: box will select all points whose feature code contains "AV", equivalent to *AV*.
    There is more information about other regular expressions you can use in TBC help under the section "Select Using Advanced Criteria", this can be accessed by pressing the "F1" key while in the Advanced Select command pane.
    I hope this helps!
    Matt
  • 3.  Re: Select with wild card (*) in Feature code
    Posted 08-07-2018 21:55
    Thanks a lot.
    The first one worked in my file.
    The second ("AV") did not work. !!!
    Anything I am doing wrong?
  • 4.  Re: Select with wild card (*) in Feature code
    Posted 08-08-2018 09:18
    My bad, there are no quotes. Just AV . I could have made that more clear!
  • 5.  Re: Select with wild card (*) in Feature code
    Posted 08-08-2018 21:02
    Thanks a lot
