Catalyst and Samsung Note 7-9
  • 1.  Catalyst and Samsung Note 7-9
    Posted 09-29-2018 21:47
    Could you please let me know if Samsung Note 7- 9 is compatible with Catalyst and Penmap
    Thanks.
  • 2.  Re: Catalyst and Samsung Note 7-9
    Posted 10-01-2018 15:55
    Penmap for Android is compatible with Samsung Note 7-9. I am quite sure that Catalyst is also compatible but I will check out for you.
  • 3.  Re: Catalyst and Samsung Note 7-9
    Posted 10-04-2018 12:32
    I use both in a note 8 and it works fine.
  • 4.  Re: Catalyst and Samsung Note 7-9
    Posted 10-04-2018 13:14
    Hi Lucas, thanks for confirmation.
    As I could figure out we are quite sure the the other ones will also work.
    A official list with tested hardware could be found with the following link
    Trimble Catalyst | Compatible Devices
