Vertical Alignment From Surface Profile
  • 1.  Vertical Alignment From Surface Profile
    Posted 09-09-2019 20:35
    I intend to create a VAL from a Surface Profile of an Alignment and record it in a corridor by the same name.See attachments.
    I tried what Mr Alan suggested. Could not go through. Will some on hep please.
    Thanks.
    Attachment(s)
    pdf
    Create VAL.pdf   4.24 MB 1 version
    zip
    AAM-GIS-2.vce.zip   22.27 MB 1 version
  • 2.  Re: Vertical Alignment From Surface Profile
    Posted 09-10-2019 08:28
    Here is a quick outline of the steps.  I suggest that you work through the tutorials and videos (Retrieve) related to corridors for more tips.  A link to these can be found on the support tab.  Your dealer may also be able to arrange some additional training.
    Create an alignment (HAL) using a line
    Create a surface profile using the hal
    Create an alignment profile view of the hal
    Create a new line in the profile view or use the surface profile just created
    You must create the line in the profile view using the same stationing of the HAL
    If needed move your line in the profile view to the correct beginning station
    Edit the alignment (HAL) and click on the vertical tab
    Click on the create vertical alignment button
    Click on the append to alignment command icon
    Pick the append vertical option
    Pick the line from the profile view
    A HAL can have multiple VALs
    The controlling VAL is set in the property of the HAL
    Hopefully this outline will get you started.
  • 3.  Re: Vertical Alignment From Surface Profile
    Posted 09-10-2019 20:52
    Thank you very much.
    Going forward, Could you please resolve another issue for me.It is also
    from the same job. In the *.xlsx file, Elevations are missing. Why?
    Thanking you again.
    Regards.
    On Tue, Sep 10, 2019 at 7:29 PM tim_mcclannahan@trimble.com <
    Attachment(s)
    xlsx
    Mafrooda 1 CL.xlsx   10 KB 1 version
    zip
    AAM-GIS-2.vce.zip   22.38 MB 1 version
  • 4.  Re: Vertical Alignment From Surface Profile
    Posted 09-11-2019 07:30
    Your horizontal alignment is 2d.  Once you define the vertical alignment it is 3d and will report the elevations.  The elevation is taken from the VAL or selected points and lines.  The depth is the depth from the val to the surface
  • 5.  Re: Vertical Alignment From Surface Profile
    Posted 09-11-2019 20:44
    Thank you for the clarification.
    On Wed, 11 Sep 2019, 18:30 tim_mcclannahan@trimble.com, <trimble@jiveon.com>
  • 6.  Re: Vertical Alignment From Surface Profile
    Posted 09-19-2019 08:44
    I usually convert the 2D line to 3D first using "ChangeElevation"->"Surface Elevation".
    Once you have the 3D polyline you can easily create the Alignment out of it.
  • 7.  Re: Vertical Alignment From Surface Profile
    Posted 09-20-2019 21:33
    Thanks.
    On Thu, Sep 19, 2019 at 7:44 PM ronny.schneider@sitech.ch <
