I was trying to create side slopes with some conditions.
At one location I am getting some issues. The first instruction is not getting followed as desired for unknown reasons. I tried to edit the line string hoping to manually correct the error but was not successful. I have highlighted area of problem in the attached file.
Could one of you please look into it suggest a solution.
Thanks.
