Thank you very much.
Will work through this and revert to you.
Elevation points I had were all from Cross Sections at regular intervals
along a Road Center Line. As a result, at locations where the Road edge
line curved sharply away as in a Lay by, the chords were significantly off
the curved 2D line. The client was insisting, for purposes of incorporating
in GIS files (Geomedia), he needed the 2D Geometry to be strictly followed
and Elevations imposed on them. I was wondering if you had some trick up
your sleeve.
I convinced him to accept shorter chords (say 1m Length), regenerated the
cross sections at shorter intervals only at desired locations (Not in TBC),
exported points as a csv file and generated a 3D line string for each road
element by "Connect Points" Command in TBC. I then exported the lines to
AutoCAD for submission.
I have submitted the data to the client and awaiting his formal approval.
Thanks again.
On Tue, Jul 30, 2019 at 7:23 PM alan_sharp@trimble.com <trimble@jiveon.com>
