Create Points by Station Offset Ele
  • 1.  Create Points by Station Offset Ele
    Posted 05-04-2019 00:17
    This has reference to reply by @Wayne Welshans Wayne Welshans Apr 29, 2019 6:49 AM
    "Create point by Staion......"
    I tried it, but did not get the desired results.
    A progress bar ran through quickly, no message appeared. But there were no points created in the "Point" layer.
    Can I have some more help.
    I attach the data.
    Attachment(s)
  • 2.  Re: Create Points by Station Offset Ele
    Posted 05-06-2019 08:28
      |   view attached
    Saif
    1) When you import these CSV Files use the Import Command and set the Importer to look in the folder where the CSV Files are placed.
    2) When you see the CSV Files in the Importer they should say Station Offset Elevation File Type - if for any reason they do not say that then you can select the file, right click and "Set File Type" and you should be able to change it to Station Offset Elevation - Mine worked fine for me
    3) When you select one of the files - look at the base of the Importer - there are two settings - the first allows you to choose whether you want to create Points or Stored Cross Sections from the imported data - you may want both of course - if so then you can import the file 2x to achieve that. Either way you will get a Surface Model made from the imported data as well as the Points or the Stored Cross Sections.
    4) The second setting states whether or not the import file has Point IDs in Column 1 or not. Sometimes we get Point ID, Station, Offset, Elevation, Description and sometimes just Station, Offset, Elevation, Description - you have to set this setting correctly for the file type that you have (because a Point ID will give crazy Stations if read incorrectly etc.)
    Once set up correctly, the files imported first time for me in 5.00.02 Version of TBC- here is the Project File that I created from your data.
    If you drag and drop the files - it will use whatever the last used settings were for this importer - and if the Point ID was set to No and your files have Point ID they will not import.
    Attachment(s)
  • 3.  Re: Create Points by Station Offset Ele
    Posted 01-25-2020 00:30
      |   view attached
    Revisiting this issue again.
    I do not see the desired file type in TBC 5.20.(See attached photo).
    Am I missing something?
  • 4.  Re: Create Points by Station Offset Ele
    Posted 02-02-2020 00:24
    Found the Answer.
    Thanks.
