Export to ESRI GeoDatabase file
  • 1.  Export to ESRI GeoDatabase file
    Posted 12-14-2019 01:00
      |   view attached
    Attached file was created by importing *.shp files.
    I exported all objects (723 Objects) to ESRI GeoDatabase file.
    1. On inspection of the gdb file I find that two additional layers are created by default - one containing all points and the second containing all lines. Is there a way these additional layers can be avoided from creation.
    2. By default the Shapefiles limit  (truncate) the Property headings to 10 Characters. The gdb deliverable is required to have the full heading (No Character limit). Is there a way the headings can be edited within the gdb file?
    Thanks.
    Attachment(s)
    zip
    MZ39 SWD.vce.zip   142 KB 1 version
