Hi Rui,
I'm not sure if it is a TBC Exporter or AutoCAD limitation that when Exporting to DWG with the "Export point as Point Block" & "Export attributes" Options enabled - only POINT_NUMBER, DESCRIPTION (CODE) & ELEVATION are passed through to the Point Block Attributes - none of the Attributes are passed though to the exported DWG.
Point Descriptions has this same problem too of not passing through to DWGs.
The more data we can pass through on these Exports to DWG (attributes and/or descriptions please) I'd suggest would greatly enhance many workflows & end user deliverables to our clients.
Can Trimble investigate if this is a TBC or AutoCAD limitation?
Thanks,
Liam
