Chainage Offset Elevation Report on not fixed chainage
  • 1.  Chainage Offset Elevation Report on not fixed chainage
    Posted 07-23-2019 07:13
    Is there way in TBC to get in one  'Chainage Offset Elevation Report' reading to stations which aren't on even stations?
    At the moment I create spare report for each chainage but I'd like to be able to add each chainage and create one report in one go (something similar when you do Sheet Settings->Cross Sections Locations and you are able to add additional locations).
  • 2.  Re: Chainage Offset Elevation Report on not fixed chainage
    Posted 07-29-2019 16:19
    If you are talking about a Corridor Model - you can do the following
    Create an instruction - use Offset Elevation and set the Offset to by Table and then in that Table enter all the Stations where you want outputs and use Offset 0. Set all Elevation Deltas to 0 also. Do not apply the node to any Material Layer in the Corridor. I typically place an instruction at the start of the Template before any "meaningful nodes". This will generate additional output lines at all the noted Table Stations along with Intervals (set to 1000000 if you dont want to report Intervals) and Start / End and PC / PT / VPI locations etc. as well as any other Table Instructions or Lines (2D or 3D that have nodes in them). If you just want specific Stations and nothing else I don't know a way to do that today other than using a Code of some kind to sort the data by in Excel.
    If you have points at Random Stations and you want to report those you can do that using the Station Offset or Pavement Conformance or the Points to Surface Reports.
    I will take a longer look at this tomorrow to see if I can find any other way.
