Slice through lines
  • 1.  Slice through lines
    Posted 03-08-2019 05:54
    Is there a way in TBC to create line by slicing through other lines as per picture below.
    Final Line should have nodes and elevations from intersections points.
  • 2.  Re: Slice through lines
    Posted 03-08-2019 05:57
    I don't think there is, but that would be a great #feature_enhancement
  • 3.  Re: Slice through lines
    Posted 03-08-2019 10:47
    Here is a video showing what we can do to accomplish this in TBC today. Linestrings in TBC are the equivalent of 3D polylines. I give credit to @Heinz Lichtenberg for showing me this a few months ago!
    @Radoslaw Myszak What would this be used for specifically?
    Cheers,
    Matt
  • 4.  Re: Slice through lines
    Posted 03-12-2019 07:21
    So I think TBC has a pretty intuitive way of doing this in the Data Preparation section.
  • 5.  Re: Slice through lines
    Posted 03-13-2019 03:23
    Thank you everyone.
    @Matthew Pitt  your way seems to be the best but with my licence Elevate line isn't active.
    Agree with @Wayne Welshans Wayne Welshans that it would be a great #feature_enhancement.
    @Matt McLean I use this to many things, often to do quickly cross sction through roads - often prefer to use this option becouse it snaps to lines instead to surface where it snaps to all 3d faces.
  • 6.  Re: Slice through lines
    Posted 03-13-2019 10:17
    I will add this to the enhancement list! I can see how that is useful for road cross sections. What is the name of the command you used in your GIF?
  • 7.  Re: Slice through lines
    Posted 03-14-2019 07:02
    @Matt McLean it's lisp routine called Slice3dPoly.
    I'm not sure if I can share competitors stuff here but if you want I can eamil you.
