"Reduce extents and try again" error when trying to publish designs to library.
  • 1.  "Reduce extents and try again" error when trying to publish designs to library.
    Posted 08-30-2019 13:09
      |   view attached
    I am trying to publish designs to library and I keep getting a "reduce extents and try again" error. I have successfully published to library with other job sites before with no problems and the site that I am publishing is relatively small in size. Has anyone else run into this error before?
  • 2.  Re: "Reduce extents and try again" error when trying to publish designs to library.
    Posted 09-04-2019 07:54
    Dennis,
    If you want to share your project file by emailing it to me directly via my community address, we can try to debug it.
    David
  • 3.  Re: "Reduce extents and try again" error when trying to publish designs to library.
    Posted 09-05-2019 06:34
    Where do I find your community address at?
  • 4.  Re: "Reduce extents and try again" error when trying to publish designs to library.
    Posted 09-05-2019 07:24
    I figured out why it was giving me that error. I had multiple UCS Circles and once I replaced them the problem was solved.
  • 5.  Re: "Reduce extents and try again" error when trying to publish designs to library.
    Posted 09-05-2019 10:00
    That will do it Dennis!
