Beginning Template Station.
  • 1.  Beginning Template Station.
    Posted 05-11-2017 05:41
    I created a corridor and assigned a template from the beginning station. It doesn't start until 17.71 feet after the beginning station. And it ends 10.47 feet before the end station. How do I apply the template to the entire alignment?
  • 2.  Re: Beginning Template Station.
    Posted 11-20-2018 07:49
    I'm way bit late to this... Densify your corridor under the surface properties or change the corridor sampling distance to something small, IE 1' under Project Settings>Computations>Maximum sampling distance. There could also be not vertical information on the alignment at the beginning. This would do that as well
