I only used the Define AOIs as an example - that really only applies to the
Takeoff workflow. If you are modeling and computing volumes or creating
drawings then the AOI approach is not necessary. When you apply Surface
Boundaries to a Project, if there are 2 distinct areas like in your project
then I would typically build two boundaries and apply two boundaries to the
surface - where they are separated like in your case - they will become two
island models and volumes would only come out of those areas filled by the
CF Map. If one boundary was inside the other then they will form a
"Doughnut" ie a Surface with a hole in it. If you have multiple islands
inside an outer boundary then you will get multiple holes in the surface
etc.
While you can do what you did, I personally try to avoid complicated
boundary shapes, especially if they don't work first time. The problem with
models is that every one is different and is ceated in a different way, and
we sometimes find small defects such as this, caused purely by combination
of data issues - we try to resolve those as they arise and that makes the
modeling engine stronger for the future.
Thanks for flagging the issue
On Mon, Sep 30, 2019 at 11:13 AM esalgado@yantiscompany.com <
