Feature Request - Create Point Feature Coding
  • 1.  Feature Request - Create Point Feature Coding
    Posted 11-27-2019 21:34
    In the create point command the feature code can be entered manually or the cumbersome feature code editor can be opened to find codes
    Trimble Access again far outshines TBC here
    In Access when tapping  in the code field a dialog box pops up where you can sort and dynamically search by either code or description.
    The measure codes functionality in Trimble Access is a great feature and a configurable measure codes dialog box under the code field would be a huge addition. Much better in the create point command compared to a separate TML
    Measure codes also has template pickup, the +/- for quickly changing string numbering and find getting the next free string number.
  • 2.  Re: Feature Request - Create Point Feature Coding
    Posted 11-28-2019 11:20
    I will forward the request to the Geospatial Product Management team for review. I can see your point when you are using Feature Codes to drive Feature Processing throughout a project delivery.
