Hi ,
I've converted your images to Blocks and hopefully they are attached. (Sorry, couldn't work out how to attach them to a reply)
I'm trying to add AutoCAD Blocks to my Feature Library but adding multiple insertion points.
In the case of the arrow, First Insertion point is the tip of the arrow, The second insertion point is the base.
This should scale my AutoCAD Arrow blocks between these points.
Currently experiencing a couple of issues.
Sometimes, I cant open my new Feature Code Library and receive the following messages.
Error while opening file F:\04052025d.fxl.
Error message: The element 'PointLabel' in namespace 'http://trimble.com/schema/pointlabel' has invalid child element 'UseNumberGroupSeparator' in namespace 'http://trimble.com/schema/pointlabel'. List of possible elements expected: 'Prefix' in namespace 'http://trimble.com/schema/pointlabel'.
Error while opening file F:\02052025 .fxl.
Error message: The 'IsLabelVisible' attribute is not declared.
When I open TBC, open a New project and process the data using the FXL file, it works fine.
However, when I export as a DWG file, selecting CAD, DWG Exporter, Options, Select by Layer and select all layers, I have no point name description or elevation data.
Any help will be much appreciated.
