Delta edit vertical alignment
  • 1.  Delta edit vertical alignment
    Posted 09-12-2018 15:01
    How is the best way to edit an entire vertical alignment up or down by the same elevation change?
  • 2.  Re: Delta edit vertical alignment
    Posted 09-13-2018 13:23
    Hey Glenn,
    There are no direct tools to my knowledge that will do a delta shift of an Alignment entity in BC-HCE.
    In order to easily accomplish your goal, I use the offset tool menu....
    • Offset the alignment by 0, horizontally,
    • Apply your delta offset under the vertical portion
      • That will create a linestring with your offset applied.
    • Create another alignment with the newly created linestring, appending both the horizontal and vertical values.
    You will now have a 2nd alignment to work with.  If you have a corridor that you have attached everything to, edit the corridor and apply the new horizontal and vertical alignment.  Your model will adjust.
  • 3.  Re: Delta edit vertical alignment
    Posted 09-13-2018 19:38
    Glenn,
    Create a Profile View, Select everything and move FROM Pick end of VAL (0+00, 735.50) TO type (0+00, 736.60)
    Or whatever your station and end elevation is.  CHECK, CHECK.CHECK.
  • 4.  Re: Delta edit vertical alignment
    Posted 09-14-2018 06:29
    Awesome!  I did not know that this Terramodel trick is also in TBC!  Thanks for sharing!
