I'm performing a takeoff for a job that requires regrading the existing slopes of a canal if they are steeper than 2H:1V. The canal is a little over a mile long and I'm hoping there is an easier way to check the slopes than using surface slicer every few feet.
Ideally I would like to be able to create a heat map that only highlights my specific slope ranges. Is there an existing command or work around that could help achieve this?
