Can't find model tab to start the geometry creator function
  • 1.  Can't find model tab to start the geometry creator function
    Posted 11-24-2020 08:48
    Would like to define a  plane to complete a surface to model inspection.  A Trimble Realworks tutorial indicates this is done in the geometry creator under the model tab.  I do not see a model tab. I am utilizing version 11.3.1.104.
    Thanks
  • 2.  Re: Can't find model tab to start the geometry creator function
    Posted 11-24-2020 09:00
    Kevin
    This post needs to be on the Geospatial Forum not this one for TBC for Construction. Here is the link where you should make your post in order for the Geospatial Team to respond to your question
    I apologize but I have no knowledge of Realworks at all - I see your question at the below link already so I hope that you get a response from the Geospatial team. I am not clear why the post ended up where it did on the CEC TVBC Forum
    https://community.trimble.com/community/find-answers/pages/forums
