Selection Set filters are an area that would greatly benefit from a filtering combo box or some sort of filtering. This would dramatically increase the speed of navigating through this list, especially on larger projects.
One example of this is when dealing with spj files. Sometimes you need to have the spj file selected and sometimes you need the surface as well. A filter would allow you user to quickly isolate both, otherwise these can be scattered across an expansive list.
Thanks for considering.
#enhancementrequest #UI #UX
