Hi there. I'm using TSC7 controller with S8 jigger and R10 rover. I have to connect it to IDS Stream-C ground-penetrating radar. Does anyone know how to do it? I managed to connect it to Leica CS15 controller TS15 jigger and GS15 rover without problems. Thanks
Hi Artur,
Would you pass this question to geospatial_support@trimble.com, our support team has more knowledge and experience about the field operations than we do.
Thank you.
Rui
Can you pass it to them for me please?
In Trimble Access General Survey go into Instrument and select Data Output. The most common output format for GPR would be Pseudo NMEA GGA. If you need assistance in setting it up, contact one of the Australian dealers.
