I have a surface model built from point and line features. In order to draw cross sections over this surface, I have to create an alignment and then a corridor. I can get the section close to how I need it. Although I can't filter out the drop lines from where the section crosses lines in the triangulation, which would be nice. I'm trying to get the line name as shown to appear in the table below the section, as I have it labelled above the line location as shown in the picture. Does anybody know if the Code option in the Cross Section Table settings, only works with "proper" corridor designs or is there a way to pull the Code labels from a surface?
![Cross Section Table - Code label row](https://community.trimble.com/servlet/JiveServlet/downloadImage/2-34355-155760/1387-900/Section-Nodes2.JPG)
