WMS (Ohio North)- TSC7
  • 1.  WMS (Ohio North)- TSC7
    Posted 01-05-2021 06:29
    I am trying to set up a web map service for the TSC7. I got Ohio South zone to work just fine but am having issues for Ohio North... After entering the URL and running the test, it does not give EPSG: 3734 as an option for the coordinate system. Is there anyway to override it so it recognizes that? Or is this an issue with the url? The job file itself is set to the Ohio North zone.
    Link to the WMS containing the URL:
    https://geo1.oit.ohio.gov/arcgis/services/OSIP/osip_best_avail_1ft/ImageServer/WMSServer?request=GetCapabilities&service=WMS
    Actual URL I entered into the WMS setup in the TSC7:
    (Main link REST Service Endpoints)
    Thank you!
  • 2.  RE: WMS (Ohio North)- TSC7
    Posted 01-05-2021 15:55
    My addresses for WMS have a ? on the end. Have you tried that?  I have some issues with the Ohio OGRIP WMS links. For instance, in order to get the same all of Ohio best 12in aerials to show up, I need to set the coordinate system in my JOB to South zone while I'm actually in the North zone. If I choose the correct zone, it shows that I'm in the south half of Ohio.  Though the best available 6in link shows up correctly when set to the north zone, though it does not cover all over Ohio yet.
    Robert Hoy
  • 3.  RE: WMS (Ohio North)- TSC7
    Posted 01-05-2021 17:51
    Thank you for your help and insight Robert! So I did add the "?" to the end, although it does not seem to make a difference. I was able to get the 6" inch aerial working for Ohio North; however, like you mentioned, it does not cover all of Ohio. When I try to use the 12" aerial, I get the same thing with it showing up in the southern half of the state. When I set the coordinate system in the job file to Ohio South (even though it really should be North), the aerial is still showing up incorrectly (only did one test though). However, I don't think I will test it any further though because even if I can get the 12" aerial to display correctly by setting it to the incorrect system, that is not a practice I want our crews to be using.
    For Ohio south zone, I can get the 12" aerial to work correctly, but not the 6" inch...
    I am wondering if it is something that is wrong/imbedded into the meta data?
    For example, for the 12" aerial, looking thru the page linked below, it lists EPSG:3754. But, for the 6" aerial, it lists EPSG:3753...
    12":
    6":
    https://geo1.oit.ohio.gov/arcgis/services/OSIP/OSIP_6in_best_avail/ImageServer/WMSServer?request=GetCapabilities&service=WMS
    Almost as if someone set up the 12" for Ohio South and the 6" for Ohio North maybe but not both zones for each?
    I might try to reach out to someone with OGRIP as well...
    Thank you again for your help!
    Brandon
    Brandon King
