When I create an Alignment, at times i use a point to grab the coordinates and today i tried using a station offset to get coordinates. I notice this when I do the POB where once the coordinates are in the two cells (N,E). I have to manually move down a row for the next segment instruction. Once I do this, my POB coordinates are turned back to 0.000. There are times I can get it to stick when using points. When doing the station off I can not get the N,E to stick in the POB cell.
1) is there a trick to this or is this a bug?
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/MessageImages/26b2ed25e9f94e0c9112768574eaff7b.png)
![](https://higherlogicdownload.s3.amazonaws.com/TRIMBLE/MessageImages/94708a0c0b184332a8bc40e491d4cbeb.png)
Francisco Guerrero
