TSC2 TGO Problems
  • 1.  TSC2 TGO Problems
    Posted 01-23-2021 02:51
    Hello everyone,
    sorry in advance if I'm in the wrong forums, I cannot find a specific forum for my problem.
    I have an old TSC2 with R6 and I am trying to use TGO to import data from the TSC. This device requires SyncCenter (XP) or MobileCenter (Vista/7) but I am on Windows 10. Previously I had old PC but it's not running anymore, so I installed XP in VMware, TGO installed, TSC recognized as GenericSurvey etc. There are problems with TGO:
    1) If I try to import USB from GenericSurvey, at the end of transfer an error message popup: "Wrong DataBase Version : Actual: 1.60, Expected: 1.30", and I have to abort the operation. Never seen this error before.
    2) If I copy the obj file manually, and import directly in TGO, "Out of memory" error shows in XP, 7, virtual machine or non-virtual-machine.
    I wonder if there is an external utility to convert obj to .dc file without going through TGO or how to solve the these problems.
    Thank you!
    Darius Smith
  • 2.  RE: TSC2 TGO Problems
    Posted 01-23-2021 19:59
    I don't know if you are using Access or TSC on your TSC2, but with Access you can export your data to a .dc file.
    Robert Hoy
