Trimble Access V21.00 converter?
  • 1.  Trimble Access V21.00 converter?
    Posted 02-25-2021 10:06
    I just updated my Access software to V21.00 and am now getting an error in TBC that says the conversion is not supported. My TBC version is 5.40 (5.40.7650.15656) and when I check for updates nothing more is available. Has anyone else had this issue? The error message on TBC says my converter version is 2020.
    Thanks!
    Michael West
  • 2.  RE: Trimble Access V21.00 converter?
    Posted 02-26-2021 09:16
    So as I understand it you updated TA and when you attempt to import a .job file into TBC you get the unsupported error.
    You probably have to run Trimble Installation Manager on the importing computer. You want to install "Office Updates". I think that will fix your problem.
    Dave Olander
  • 3.  RE: Trimble Access V21.00 converter?
    Posted 02-27-2021 08:47
    If you saw my previous post on this same issue, just keep checking for updates and a remote device manager update file might show up. A workaround until then is to export JXL out of TA2021 and import that into TBC.
    Robert Hoy
  • 4.  RE: Trimble Access V21.00 converter?
    Posted 02-28-2021 16:52
    If the TA 2021 job converters are not installed in the current Remote Device Manager updater then your options are:
    (a.) Run TIM as mentioned above.
    (b.) Download the converters from the Trimble Access page on the Trimble Geospatail website:
    https://geospatial.trimble.com/trimble-access
    From here go into Downloads - Trimble Access, then select Download the Update Office Software package for Trimble Access. Select and install Update Office Software for Trimble Access v2021.00, February, 2021.
    James McWha
  • 5.  RE: Trimble Access V21.00 converter?
    Posted 03-01-2021 05:57
    Thank you everyone for your help. I was able to find the updated remote device manager.
    Take care!
    Michael West
