Can you please highlight the lines your are actually using in your template and also upload a screenshot of the template editor.
From just this one screenshot I have no idea what you've done so far and what string lines are available.
Or, better, upload the project.
The sideslope with a line string as limit should look like this in TBC. The only thing I ran into during this quick test with a corner string line is that the triangulation is wrong. No matter what values I set for the maximum edge length, maximum edge angle, sampling distance, breakline approximation values, densification etc.. Not sure if this is some kind of bug or just an overall limitation.
@Alan Sharp would probably know.
If I use a fixed value for the offset the triangulation is ok, but it's past the limit of course.
Sent: 09-18-2021 03:18
Subject: How do i extend my corridor surface to cover L Shaped Bend on a bridge?
I'm trying to model a pedestrian bridge above using the alignment @1% slope on either side of the alignment.So far so good until it reaches the highlighted L shaped bend.I tried 2D line command to extend the back of kerb string line but still face issues.Is there an option to extend all my kerb lines/surface to the L shaped bend?
Thanks
Julius Joseph
