Conducted a 6 hour static Survey on 2 Control Points/Benchmarks with two R8 GNSS Receivers, and a third receiver on an unknown point with a NetR9 and a Choke Ring Antenna. When I download from the WebUI interface and import the static data from the NetR9 into TBC, it automatically assigns the data from the reference station as Control Quality while those from the two R8 receivers are just fine. My thinking is the data is behaving that way cause the NetR9 is a Reference Station Receiver and I might have to redo that survey with a different receiver mounted on the unknown point...that would be a bit unpleasant to find out but good to figure out what the issue is.
The issue here is that I want to Assign [Add Coordinates] Local and Grid Coordinates and Height|Elevation to the point data from the two R8 Receivers then use them to Process the data from the NetR9…Issue now is the NetR9 data point is importing as a Control Point and works like I'm using the NetR9 data to process the baseline btw it and the two R8's
The data from both R8's happens to have broken due to battery shut down, but mostly they continued shortly after replacing that promptly.
Excel sheet from within the link has other info that might be needed.
Here's a
link. to the file and , would appreciate if someone could take some time to look at it and maybe proffer a fix if one exists.
Tomisona.
TOMISONA ISIJOLA
