I know this is not really the right group/community to post this to, but I have not found anything related to Trimble Access.
I came across an issue with Trimble Access today. I was shooting several points in both faces, but pretty much for each point I got the "Out of tolerance" message between F1 and F2, which almost never happened to me before. So I checked the raw data and the differences in angles and distances between F1 and F2 surely did not correspond with the differences in coordinates, which were much bigger. It is especially obvious in the attached screenshots, where F1 and F2 have the same distance and the same hor. angle (+180 deg. of course), but the coordinates for F1 and F2 differ by 6 mm, while, obviously, they should be exactly the same. Did this by any chance happen to anyone or anyone knows what this glitch is caused by ?
Thanks.
Lukas Zifcak
