Im looking to have any possibility to export points AND figures(lines rectangles circles created using feature codes in field) to Civil3D. The thing is I dont need dxf/dwg - which means just drawing. I need to import it by fieldbook file, to let Civil3D use it as a survey data, not just a drawing which is essential for me. While surveying on trimble access in the field is much more easy for me to use Trimble coding method than coding for Civil3D to make linework processing there. For me also is very important to use 3 point rectangle method for automatic creation of rectangles , which in Civil3D is very poor or I would say even not exist(3rd point need to be a corner also and accuracy of this point influencing on shape of rectangle - can create quadrangle instead of rectangle.
See small piece of Fieldbook which Civil3D exports(and also can import...), first part is about points, second part is definition of figure which is possible to draw only with point data part.
NE SS 536875849 726760.63700000 708056.89500000 100.93500000 "VL8"
NE SS 536875850 726765.87300000 708065.58700000 100.71300000 "VL8"
NE SS 536875851 726757.35000000 708069.14800000 101.73600000 "VL8"
NE SS 536875852 726751.71100000 708063.36800000 101.68200000 "VL8"
NE SS 536875853 726749.22500000 708053.84400000 101.81700000 "VL8"
NE SS 536875854 726767.18700000 708070.99100000 99.95000000 "VL9"
NE SS 536875855 726767.03700000 708070.87600000 100.57800000 "VL9"
NE SS 536875856 726771.45100000 708072.39200000 100.28600000 "VL9"
NE SS 536875857 726773.31600000 708079.00400000 100.22900000 "VL9"
NE SS 536875858 726776.87400000 708086.22900000 100.07600000 "VL9"
NE SS 536875859 726780.34400000 708095.56700000 99.93300000 "VL9"
NE SS 536875860 726786.11900000 708103.11700000 99.86100000 "VL9"
NE SS 536875861 726789.84400000 708114.16300000 99.86300000 "VL9"
NE SS 536875862 726793.64900000 708121.22300000 99.84700000 "VL9"
NE SS 536875863 726787.83300000 708121.80500000 99.80800000 "VL9"
NE SS 536875864 726779.73500000 708116.77600000 99.87000000 "VL9"
NE SS 536875865 726777.84200000 708110.18000000 99.76200000 "VL9"
NE SS 536875866 726774.51100000 708098.53100000 99.98500000 "VL9"
NE SS 536875867 726775.37900000 708092.23900000 100.16500000 "VL9"
NE SS 536875868 726765.54500000 708090.37600000 99.86600000 "VL9"
NE SS 536875869 726765.95800000 708080.57900000 100.89900000 "VL9"
BEGIN BAR1
PT 536873336
PT 536873339
END ! BAR1
BEGIN BAR10
PT 536873957
PT 536873958
END ! BAR10
BEGIN BAR12
PT 536875249
PT 536875250
PT 536875251
END ! BAR12
BEGIN BAR2
PT 536873337
PT 536873338
END ! BAR2
BEGIN BAR3
PT 536873358
PT 536873361
END ! BAR3
BEGIN BAR4
PT 536873359
PT 536873360
END ! BAR4
BEGIN BAR5
PT 536873756
PT 536873759
END ! BAR5
I found something named Feature Spredsheet and it seems to be kind of data which I need but I cannot find option to export this data...
Can you help me?
Michał Czyż
